Stage2Buick
- Oct 16, 2010
OK, I wasn't planning on selling this motor but I have to in order to finish another project. This motor was built by Hye Tech Performance. It was taken out of a car that ran 9.50@145mph with full interior, power windows and A/C. I'm sure in a lighter car this would easily be an 8 sec car. It has a lot of R&D in it so you know this combination works using the stock intake. The intake was ported to match the heads and if anybody knows the stock intake will not bolt up to M&N heads. Part of the deal when I bought the motor was that it had to be disassembled, thoroughly inspected and put back together w/new rings, seals, gaskets, bearings, timing chain, and oil pump.
I spent a total of $15000 will take a loss at $13000
I will post up pictures soon.
Here is a parts list:
3.8 stage 2 off center block .30 over
billet main caps
Clevite H series main bearings
Callies crank shaft 3.590 stroke
JE pistons
Hellfire rings
Carillo rods 6.200
Comp Cam lifters
Comp Cam solid roller 643 int. 660 ex.
High volume oil pump
M&A Heads ported and polished on exhaust side
2.08 intake 1.60 exhaust
T&D 1.65 shaft mounted rockers
Accufab 70mm throttle body
Kenne Bell intake plenum
83lbs. injectors
Kenne Bell fuel pressure gauge
76mm turbonetics turbo
Tial wastegate
Custom built buick headers
![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
billet main caps
JE pistons
Hellfire rings
Carillo rods 6.200
Comp Cam lifters
83lbs. injectors
Tial wastegate
