stage 2 pistons
limitedv6
Stage 11 in the work's
Does anyone have any 4.045 or bigger pistons for a stage motor may use a set of flat tops. I would need them for a 3.625 stroke and a 6.5 rod if I can cut them down to lower the compression let me know what you have Thanks
what I exactly need is a set of dished pistons for a 3.590 crank and a 6.5 rod. I figured if I play with a flattop piston and it was setup for a longer stroke it would help drop it in the hole a little more was my thoughts. I will also entertain new pistons if anyone has a rough price on a set also thanks in advance.
