Stage II Black/Chrome Turbo T
fatride
Senior Member
Ive been working on this car for awhile now, and I just simply lost interest in the car. I haven't drove this car in over 2 years. My work schedule doest give me the time to work on it, and the car just sits. The motor is fresh, OC stage II. 3.965 bore, bock has cross bolts for front main cap, BMS 3.50 Std/Std. crank, 6.5 Carrillo rods, JE's, Solid Biller Roller 232/232 cam, White Racing HV cover ext. oil pump, Custom Sheetmetal oil pan, HR mounts, Stage II BMS ported heads, T&D's, Car has A/c still in it. The car will need a few things to complete.* Will need your choice of headers, intake, turbo. These parts I borrowed from a good friend.
JW wheel
HR motor mounts
RJC pullies
Turbo Saver
PTE front mount
Be cool radiator w/ dual fans
160lb injectors
Weldon 2015 external pump (fresh from Kinsler)
external fuel regulator
FAST XFI
-8 feed line -6 return
4" cold air kit
10.4 wires
3" aluminum Drive shaft
Moser axles, Eaton posi
Meto adj, uppers, Metco lowers
Rear end girdle
Air bags/ Bilsteins
Front Eibach springs
SSBC Brakes/ drilled, slotted rotos
Drag Stars 15x3/15x8's
Int. has the usual guages, laptop stand
Brand new Fully built BOP TH350
Super drum, rollerized bearings Hipster VB/brake
We had the car recently on the dyno, had ingnition issues, and major header leaks. Car made 405 on the dyno at 6psi.
I'll be working on getting pics up. The car always won in any car show it was entered in. It's a very clean car!
$19,000
I'm having a hard time posting pics.. PM me if your serious, and I'll get pics sent to you. I would concider a trade+cash for a nice HT GN street car...
are you interested in trades?i have a super nice low mile typhoon with built motor.can send pics.call or text me 828-442-5950
paint 013.jpgTo everyone who has PM'd me.. I'm working on a deal now for the car. I should know something by this weekend.
