Stage II GN - 4L80E (Rossler Transbrake) & Air Conditioning
Eticket
Thanks to Bryan in helping me clean up this listing.
Engine
270” Buick Motorsports Stage II Block new on build.
3.59 Stroker Crank - New to this build.
Crower Billet Rods
JE Pistons 4" Bore - New to this build.
Precision 76GTQ High Flow compressor, 0.85 Turbine Housing
Comp Cams 232-232 Solid Roller Cam
Smith Brothers Push Rods
Crower H11 Vasco Valve Springs
Buick 6 Cast Aluminum valve covers
GN1 Race Ported Heads/ T&D Rockers
Bowling Green Intake with 83lb injectors
FAST SEFI ECU with Individual Cylinder Control WB02
BHJ Balancer and JW Wheel - new on build.
ATR 3 Bolt Headers - new on build.
Custom 2 piece 3.5” Stainless Down pipe with External Gate
Innovative Motorsports Boost Controller
Trick Max high Volume oiling system.
Transmission
4L80E - Just Freshened with new and electonics.
Rossler Transbrake
Red Eagle Clutches
Billet input Shaft
FAST Electronic TCI Transmission Controller
TCS 9x11 Billet Converter Custom Made
B&M Cast Aluminum Pan
B&M Super Cooler
-6an Transmission Lines
Custom Carbon Fiber/Kevlar safety shield
Air & Fuel
14” K&N with ATR Cold Air Box
Accufab Throttle Body - 70mm
Dequick CAS V1 Air to Air Intercooler - Powder coated pipes
New Aeromotive Pro Series Pump
Aeromotive -12 Pro Series Pre-Filter
Aeromotive -10 Fuel Filter
-10AN Feed, -6AN Return lines
-04 AN Boost/Vacuum Lines
Aeroquip Lines and Fittings
New Fuel Tank & Metco Fuel Cell
Aeroquip -12 and -6 quick disconnects!
Rear
Detroit Locker C locker - $600 upgrade
30 Spline Moser Axles
C-Clip Eliminators New 3.73 Motive Gears
HP Adjustable Lower Control Arms with spherical ends.
Edelbrock Adjustable Upper Control Arms
HR Parts BIG Sway Bar
TA Performance Rear Girdle
HR lower control arm mount gussets
Body & Exhaust
Racepak Digital Dash
6Pt Chromoly Roll Bar with Removal Side and Rear Bars
PST Body Bushings
PST Polygraphite Super Front End Kit
Centerline 15x8 Telstars and Hoosier Radials.
New upper Dash pad. New underhood padding.
Carpeted Trunk padding with Turbo 6 emblem.
MANY MANY other custom built pieces
*I am currently getting the A/C in working order with new GM/Delphi Compressor, polished accumulator, and new condenser.*
Car has run best of 10.001@136.xx on very conservative tune.
Price is $32,000.
________________________________________
Due to to many inquiries with people having many parts already, I would be willing to lower the price if a buyer wants to supply their own:
$-1200 to keep FAST system
$-300 to keep Fuel Cell
$-600 to keep wheels/tires
$-900 to keep Front Mount Intercooler
$-400 to keep rear sway bar
$-100 to keep ATR air and filter box
$-500 to keep Boost Controller
This would bring the price down to $28,000!
$+500 if buyer wants Bogart Wheels and MT Slicks.
Please contact me directly for more details.
Thanks,
John Nguyen
jnguyensmu@gmail.com
See more details, video, and pictures here:
New Page 1
See this car on PINKS
Here's a Picture from the Oklahoma Ford Vs. Buick event.
We need your help to "Stomp the Stangs" next year!
Bump.
I'm interested in a light blue, silver, or white limited T or old convertible for a driver if someone with one of those is interested.
