Are the aluminum stage II head combustion chamber cc the same as a stock head, 46cc I believe. The reason I ask is I have a stage II off center and aluminum heads I haven't had assembled but had all block work done and purchased pistons. I believe the compression was suppose to be 8.5 or 9.0 with the stage II head. I believe I will use aluminum Champions with the motor now. Wondering if I have to get different pistons to do so?
