Stage II motor F/S
278cikiller
I have fresh From the machine shop a 274 C.I done 30 over 153 block this has internal oil system Stage Motor On Center Block.
Main Bearings
H Series Rod Bearings/Rods are 6.20Length
Cam Bearings
Rear Main Seal
Felpro INT Gasket
Felpro pan Gasket
Felpro Race Set
Felpro Head Gasket
New oil pump
JE Piston Rings/File Fitted
Seal Coat Cooling Jacket On Cyl. Heads
Mag crank
Resize Con. Rods/ Prep Piston
Balance new Crank Shaft, Rotating Assembly,Polish
File fit the Rings.
Block is 4.030
Wrist Pin Dia. is .927
Rod Eye Width is 1.108
Comp.Ratio is 8.5:1
The Crank is a 4340 Forged steel crank 3.625 Stander/Stander wide Journal Crank, The Heads are GN/I , with 853 Hydraulic Roller Lifters, Cam witch is 206/212 with a new Roller Cam Button With A new double Roller Timing Chain Buick Motor Sport Hub, The oil pan has had 2" added witch makes it a 7 liter pan. This Block has never been Damage or hurt its a 4 bolt splade caps. This motor is bi far one of the best stage motors in Canada. I do have pics but i can,t post them because they change the set up ASKING PRICE IS $14,000.00 Frim Please call me at 1-905-419-0704 Thanks.
