Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
I have a contact selling a complete SII on-center motor.
Trying to possibly help him move it.
It is an iron block (Not sure of the casting), with complete valve train with billet roller, complete M&A heads, crank, Carrillo rods, oil pan, headers, intake, TB, fuel rails/injectors, front cover, valve covers, vacuum pump, external oil pump, distributor, crank trigger, balancer/trigger, BMS crank, etc. Motor is apart for viewing.
The crank key was sheared and bend the exh. valves. One of the pistons may need to be cleaned up, but I could not see any other visible damage. The motor has been ran and looks like the rings are not even completely seated.
I am comfortable around stock stuff, but this SII may be over my head since I am sure there are some tricks to it.
Not really any plan to use the motor but it may be a good corner piece for a while. LOL!!
What do you think this is worth (ballpark)?
