"Stage Right" trans brakes with detent bracket
brian
Senior Member
At this time, we have some "Stage Right" style trans brakes for sale.
These function by putting the car in 1st gear, building boost/rpm to the desired level, and moving the shifter forward to release. These are not electric brakes.
Included are the parts needed (2) and very detailed instructions. Also, a new shifter detent plate for your shifter gate will be included.
If you want one, please send me mail directly to: hipsibri@cs.com
Price is $135 shipped to your door. (price now reflects the shifter detent plate that is included)
Also, we have 4340 band anchor pins for $22 shipped.
Hey Brian,
Did you get my MO? Should be there by now.
Also... Are you going to include the detent bracket with mine also? ;)
Don
Don,
Sorry, I have not seen anything from you as of now.
I will let you know if it arrives today...
Brian
Detent bracket
I just need a detent bracket. Would you sell just a detent bracket?
Yes I would.
$25 shipped.
Send me in mail for payment info.
Thanks, Brian
I am very interested in the trans brake, but what is involved for installation?
Do i have to tear into the trans at all?
How difficult is it to install? Also is this very hard on the transmission?
Thanks in advance
Thanks in advance
>The install should take 1-2 hours to complete depending on the installer. Not to difficult with common hand tools.
>You will have to drop the valvebody to install this.
>And is it hard on the trans?... no:eek: If you have a properly functioning, good condition trans to begin with, you SHOULD be fine. Although there is always an exception. (just trying to be honest)
HTH, Brian
do you still have these? & will they work the same with cloumn shift & as far as the the detent plate & column shift
I do have more brakes.
Unfortunatly,the detent plate will not work on a column shift car.
The plate goes under the factory console to limit travel of the shifter.
Brian
