BMF_Racing
ONE B.M.F.
- Apr 26, 2006
Ok, the car will stall after a burnout or spooling up on the t-brake and letting out of the throttle. I was thinking it may be the MAP sensor (MAF has been removed when MAFT Pro was installed) or the O2 sensor in the up-pipe. It could be the 2.5 bar MAP sensor, which worked fine, until we went over 20psi
(24 psi to be exact, that was about the time the stalling started). I have a 3 bar that I'll be swapping out tonight.
The other possiblity would maybe be the O2 sensor, because we've been using alot of 112 octane latey and it could be bad.
Would either one of these being bad cause the car not to go back to idle after a hard load?
The car does idle ok under normal situation, oly stalls after it has a load on it and seems to be worst when the engine is warmer ansd up to temp.
