standard bore 109 block and heads w/pan $350
tb3
elbows & a$$holes
standard bore 109 block. main caps with it. stock 8445 heads. I'll also throw in a clean oil pan
you pick up.
located in st. louis, mo
What did the engine come out of and what was the reason for pulling it out? Have you heard it run and if so did it smoke or any knocking? I would be interested once I get more info.
Thanks, Otes.
Thanks, Otes.
I think when he says block..... he means block......!!!! Like it is in pieces.
this is from a 87 na regal.
all cyl's held good compression cold.
I pitched the cam, lifters and push rods. I still have the connecting rods, and crank if somebody wants those with it.
I pulled it to have a engine as a backup, but I just acquired another standard bore block with a parts car, and I don't need 2 laying around. this engine has been on a stand covered up in the garage. no corrosion in the bores
