P Phatman Senior Irish Member Joined May 25, 2001 May 8, 2002 #1 Will I ever be able to tune my car with the EGR Port blocked with a chip that does not or has not been set up for it? What symptoms will it demonstrate and how or what needs to be done to the chip or chips to help this problem?
T TurboBob Resident mad scientist Staff member Joined May 24, 2001 May 9, 2002 #2 if the EGR passage is blocked and the chip is not programmed for it you may experience part throttle detonation. Full throttle operation won't be affected. Bob
P Phatman Senior Irish Member Joined May 25, 2001 May 9, 2002 #3 Thanks for the information Bob, that's basically what I wanted to know. Yep, I don't think I could have done a better job if I welded it closed.
