Aug 31, 2014 #1 dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Messages 4,039 just started my new motor here is the SD2 file. it had a tough time starting. check out the files attached and lmk what i can tweak thanks Attachments new motor.001.dat new motor.001.dat 1.1 MB · Views: 91
Aug 31, 2014 #2 E Eric Stage I TurboTweak Guy Joined May 25, 2001 Messages 2,668 Something is wrong with your air temp sensor or wiring. The reading is all over the place.
Aug 31, 2014 #3 dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Messages 4,039 I'll check it out for some reason my alt isn't charging the battery .
Sep 1, 2014 #4 dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Messages 4,039 So took it out today and had a very hard time to get it to fire . It would crank like crazy but not start. When it did start it would run alright . If I go above 10lbs it also starts to brake up like crazy . I'll upload another log soon
Sep 1, 2014 #5 1 1fastcobra Well-Known Member Joined Jan 24, 2012 Messages 1,228 Sounds like your cam timing is off ( injectors) With engine off loosen and turn cam counter clock wise a little And adjust accordingly
Sep 1, 2014 #6 dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Messages 4,039 Yep my cam sensor was off fires up fast now . Still have to get my trans lines to stop leaking :-(
