TurboSmart
- Nov 6, 2013
Recently did the fuse link relocation kit from Casper (GREAT KIT).
No shorts, wires are properly located, insulated, everything good and tidy.
Connected the battery, turned the key to start the car and now the start kept running until the I disconnect the battery.
Checked cables, fuse links, even the starter and is working OK.
Will check the ignition switch but will like to check with others before digging deeper.
