Was changing the positive battery cable last night and trying to get the lead off the starter when the entire stud turned before I got the nut to loosen maybe 1/2 turn. It tightened back up ok.
Is this common or a problem?
Thanks.
pull the plastic cap off the end of the solenoid and look it over. you used to be able to just buy a cap out of the Standard catalog that used to be behind the counter of every parts store..
