Starts one day but not the next
Jimmy2wires
Started last week but not on Sat. Started on Monday but not on Tuesday. Cranks but doesn't even try. The other day it started in the moring but later took a while to start and did not start at the end of the day. Seems to get fuel but maybe doesn't get spark?? Computer?? Fuel injected engine. Either no gas from injectors or no spark. Right??
I just went through this myself. If you find you are not getting spark check the crank sensor and the cam sensor. The cam sensor was my problem as the interrupter ring had play in it. Just had to tighten the bolt that holds it in place.
Here is the thread: http://www.turbobuick.com/forums/threads/any-ideas-on-a-no-start-condition.393694/
Maybe bad MAF? Twice I experienced hard starting and it was the MAF both times. But the car always started, just cranked a little longer.
Hey if it runs good 50% of the time you are ahead of most of the members here......:)
