Starts, runs but shuts off
Turbo85
I have an 87 TR and I have just put a new timing chain on. I have set the crank sensor, put a new cam sensor in and did all the adjustments. The car starts right up but will not keep running. I can start all day lone but it will die in about 10 seconds. I have checked the cam sensor and re gaped the crank sensor but the problem still exists. Fuel pressure is at 42. Has anyone had a problem like this? Have I left anything out? Thanks
starts, runs dies
No , thanks on that one, It a hypertech engine tuning chip. nothing fancy
Check all your hoses (air) to make sure everything got hooked back up and clamped down.
Hypertech Chip? #1 Throw in GARBAGE!! Buy a Turbo Tweak for Your Combo. Those Hypertech are JUNK!! I'm sure many will back me up on this one.
starts, runs, dies.
To all that responded, I have fixed the problem. I thought I could not hook up the maf sensor and still run the car. NOT, put everything back together and started today and runs, purrrrs,. Tomorrow I will install fan, and coolant and road test. Thanks all for all seggustions and responses. without this form,all a guy can do is guess. Thanks Again. Where can I get a tweek chip for a stock motor that will better perform the hyperchip?
oh almost forgot check the tps also unplug to see it it stays on:smile:
