OK, here's some numbers I thought I'd share with you, about injector sizing.
There seems to be alot of inertia about how fast you can go on what size injector, and I'm not going to get into the whys of tuning. This is just some info., as the computer *sees* things.
This is using Direct Scan and running an ecm bench.
Everything is constant between all the runs other then injector size.
To maintian a 12.5 AFR, at 255 gms/sec., at a 90% injector DC.
30#/hr injectors can only support 1,360 RPM
40#/hr injectors can support 1,460 RPM
50#/hr injectors can get you 1,510 RPM
55s get you to 1,560
BUT with 72s at a 75% DC you can maintain the same 12.5 AFR, to 5,150 RPM..
ONE BIG NOTE, most cars can't peg the MAF at that low of rpm so things aren't as bad as the appear at a glance. But I hope ya'll better grasp the **WHY** of having to rescale the MAF to get a balanced fuel flow at higher then stock HP levels. Just as a hint what my MAF, it reads 160 at full song. Then I used the PE vs RPM, and PE vs RPM to get the curve perfect at ranges other then what the MAF covers. You can just set the PE vs Temp table at what you want, but that has 0 drivibility, compared to what CORRECT is.
Oh, and 55s with a 100%DC get you to 5,150
50s at 100%DC get you to 1,560.
When you look at things as the ecm does, things do take on a new twist.
These ain't any numbers I drew out of a hat this is how the ecm calculates things. These numbers reflect the battery voltage offsets, etc..
When you out of injector, your out of injector. You want to fight detonation, blown headgaskets, that's your decision, having enough injector, and then just actually tuning is alot more fun.
HTH
Plese note these are just advertised flow rates and don't take into account the increase in flow rates as a result of increasing fuel pressure due to boost.
Hope this sheds some light on things
Oh, and if you run a WB you can verify that the ecm's commanded
AFR numbers match the the WBs, that is if you have the programming right in the ecm.
HTH
