- Aug 24, 2012
Thanks. Just looking at all of my options. I'd like to finish up the rear suspension after the holiday and jump on the front suspension next week while I have the time off.
SignUp Now!I figured I'd have to find a way to knock/pry them out. I read that you screwed the bolts themselves out, so I see why you didn't have this issue. A part of me thought about doing that just to get the job done. There is absolutely NO room to get a hammer on the front of the bolts to tap them out. It looks like I'll have to break out the 3lber and chisel to pry the bolts from the frame from behind. Man, this car is full of surprises!From what I understand you need to get behind it and whack it out, but honestly I screwed that up and took them out like a standard bolt...boy was the alignment shop upset about that!!!! But I paid them to do a job and they did it...lol
I do believe I put that in the thread....so I guess this is just a bump for you! lol
BTW: once you get a good technique on how to get them out PLEASE post them in the thread......I do plan on editing the OP and adding tips from other members into it.
I thought they were discontinued. If that's the case, I'll do what I have to do to get them out. I really didn't feel like dropping the headers just to get the arms out.You can still get the bolts from GM if you want to just replace them. That way you don't have to worry if you screw them up.![]()
Call the dealer first but the last time I checked they were still available.I thought they were discontinued. If that's the case, I'll do what I have to do to get them out. I really didn't feel like dropping the headers just to get the arms out.
I have had some just fall out by themselves when I removed the control arm, had to tack weld it back in on the head side.hope this helps,separate ball joint from knuckle,remove nuts from splined bolts set shims aside,clean threads and spray with oil reinstall nuts flush with bolt threads push control arm inward against nuts pry control arm up and down,tap nuts side to side,up and down,keep moving control arm and bolts around till they loosen. may need to put socket on bolt head smack with hammer. may take some time but they will come out.
This worked! Wiggling everything out takes a while, but it also keeps the bolt splines and frame indentations intact. Of course I'm going to have to 'press' the bolts back in now, but that won't be a problem.hope this helps,separate ball joint from knuckle,remove nuts from splined bolts set shims aside,clean threads and spray with oil reinstall nuts flush with bolt threads push control arm inward against nuts pry control arm up and down,tap nuts side to side,up and down,keep moving control arm and bolts around till they loosen. may need to put socket on bolt head smack with hammer. may take some time but they will come out.
hawkfan said:I probably won't even use the spring compressor to get the old springs out. I have a good floor jack that I can let down slooooow and some tall 6 ton jack stands, so I should be able to use the jack method to get the springs out. The less I have to use the spring compressor, the better. If I can't rent a ball joint and bushing press, I'll just take the arms to the machine shop.
