three turbos
NUNLKME
- Oct 17, 2010
Ok guys, got a question just installed a new gnx dash with all SW gages and the problem im having is with the speedo. It reads correct mph but the needle is a bit jumpy and its noisy,I can here the weight wheel if you will inside spinning kinda pissin me off being that its brand new and being that its been modified for the vss now im sure SW is not going to warranty it. I have taken it all apart inside and see nothing wrong appears to opperate correctly just a little noisy, it almost has the sound of a noisy lifter just not as harsh. It came with a new upper cable with grease in it and I bench testsed it with my old oem speedo to troubleshoot to eliminate a cable issue.Does any one got any input on this or an idea?Could my problem maybe be in the lower cable and translating through and up the new cable magnifying to the speedo?Im kinda drawing a blank here, is it worth lubing up the lower cable and what should I use? Thanks Eric
