Stick to the vinyl
microELVIS
The two sided tape on my knock sensor wont stick to the vinyl underneath my radio.
What do you guys use to hold stuff in place ? :confused:
Make sure the area is real clean. Use some alcohol. Heat the tape up with a heat gun or a hair dryer. Heat it till it starts to bubble or it gets wet looking. Then, for best results you need to figure out some way to hold up it up in place with decent pressure on it for as long as you can. Overnight if possible. In that location its kind of hard because of gravity. The key though is heating up the adhesive. Good Luck.
