Originally posted by scottyb
So, this potential location on the intake, is it under pressure or a seep?
What are the chances of me "slowing the leak" by smearing RTV on it? I know this sounds cheezy, but I aint removing the intake anytime soon.
The common sense part of me says to discourage you from doing this, however, I once sealed my Heater Core inlet/outlet with JB Weld, while it was still in the car and hooked up. It lasted 2+ years that way.
However, you're dealing with an area that is going to be impossible to get all the oil residue off the surfaces while it's still bolted down, and especially in the corners. Therefore, the RTV is going to have a heck of a time bonding to the surfaces.
You can certainly try, and there's always the possibility of it actually working. Although, good luck on the back side, if that's where the problem is...
Pulling the intake is a half-day job at best, including breaks and lunch.
If you want to do it right, then I can only encourage you to take the time to pull it, and seal it. However, before doing so, you need to determine that it's truly the problem, or else your efforts will be in vain, and you'll want to cuss worse than a ticked-off sailor!
It would be good if you could purchase a small bottle of "oil dye" $8, and pour it into the system, and then use a blacklight, or find a mechanic that will let you use his, to identify where the leaks are prevalent. You'd have to degrease everything first though, to ensure accurate results.
It's no fun to chase these problems, but, you either have to commit to going through the efforts, or deal with the puddles...
