just put new maf meter on car and still no luck i checked the fire it is firing got goo fuel press put some new pluges the only thing i did not change is the cam sensor or ecu
now i have to change the cam sensor the bolt under the cap is broke off win i tryed to undo it to check the tab on the wheel any one can help me feel free to call me 1 337 523 1165 thanks
thanks to all that help out i found the trouble the timing chain is bad it only turn the can shaft every other turn going to change it i can see if from where the cam sensor is
