87TTypeKid
- Jan 23, 2006
For whatever reason, I can't seem to figure out why my car just doesn't want to "go"...it gets relatively good mpg (17) for my knock-around driving, but its presently not going under the 14s, whereas prior to any modification I had a 13.69 pass..
My upgrades are in my sig, minus my recently added adjustable FPR..
I know the first thing anyone is going to ask is "have you hooked it up to a scanner to check your O2 volts, blms, etc etc"... the answer is no..sadly I have insufficient money to shell out for a $280 scanner and everyone around me in the area drives glorified lawn-trimming equipment.
Where should I start? The most I can deduce thus far is the following-
-slight lifter tap on the passenger side
-cracked driver's side exhaust manifold
-turbo passes oil pretty badly
-WOT occasionally gives me that "nails in a can" sound..detonation, I'm assuming?
-original 171,000 mile valve springs
-original knock sensor...worn out perhaps?
I will have a new turbo on the way soon, but I'd like to know where to go from there. Also, the links on various web pages are somewhat useless in helping me find a source for the DirectScan software and hardware.
Thank you all for whatever help you can give. I do appreciate it.
