Stock accuator causing boost creep liminting boost
EyeTalk2Trees
I have the car running great with 16# on 91 octane, I just moved to Houston and now have access to 93 octane. I tried to adjust the accuator to get more boost but its about maxed out, the WG only opens slighly causing major boost creep. Is there a solution or a slighly stronger spring pressure WG i can get? How do these guys get to 20-22# of boost? I don't have the money to convert to a external setup like a delta gate, what other solutions are there?
Add an external spring to it. Hook it to the WG and the base of the actuator (along the rod). Go to the local hardware store and they will have big selection.
Cheap. :)
