Stock Crank...Pistons and Rods..CAT Girdle..4.1 Pistons and more.
9SECVSIX
Stock Turbo crank .020-.020 fresh from shop with Calico coated main and rod bearings. 300.00 plus shipping. Have 250.+ in bearings and grind.
Good clean set of stock pistons ,low milage (std) on stock rods (freshly resized) SPS bolts
150.00 plus shipping.
Good set of stock pistons (std) on stock rods (ARP bolts) with almost new set of rings. Unknown milage but look OK.150.00 plus shipping.
PTS shallow transmission oil pan with pickup filter and ss bolts. 200.00 shipped. (48 and Canada.
4.1 J&E Pistons (8 custom) 4.020" bore. CH 1.287" .927" pin Dish 3.5"x.240"
6 are used 2 brand new ones. (clean) 200.00 plus shipping.
New 20 bolt CAT Girdle with all the hardware 230.00 shipped (48 and Canada)
Stock 87 turbo with adjustable actuator..no end play..did not smoke..unknow milage. 150.00 plus shipping.
I have pictures.
Would those be setup for use with a stroker crank and rods?
They will work with a 3.625" stroke and a 6.380" rod and they will work with a 3.400" stroke and a 6.500" rod. Best in a block with a DH of 9.500" C/R in the 8.5 to 9.0 area depending on what combo you use.
