I found this on Conley Racing's web site:
I have read numerous times that if you're going to use the 55lb/hr and larger low-impeadance injectors you have to have the ecm upgraded..well, after reading this on Conley's site, can someone tell me why you need to change something in the ecm?
I don't want to spite any of the vendors, however I'd like to know why this is done when according to a relatively reputable source, the only change needed is a fuse.. which makes sense since the coil in the injector when going from a high impeadance injector to a low impeadnace one just alters the current load/operation.
Or, is the stock ecm injector circuitry not sturdy enough to handle the lower impeadance without some sort of chip change, wiring upgrade or something?
			The Buick ECM [Electronic Control Module] is set up to drive high impedance injectors. The stock injector’s impedance is 16 ohms. (A high impedance injector.)
In the past low impedance injectors have been used, successfully with the stock ECM. However, the [FP/INJ] fuse in the fuse box must be upgraded to a 20A fuse to handle the additional current load.
 Had it happen at 100mph when my computer was getting upgraded for ME-R, a friend let me use his spare computer, it wasn't modded for 55s and it worked till I floored it.
  Had it happen at 100mph when my computer was getting upgraded for ME-R, a friend let me use his spare computer, it wasn't modded for 55s and it worked till I floored it. .
