Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
I shook all my leaves off.
SignUp Now!so what is this zip tie on accelerator cable is it like the ones you should put on the boost vacuum lines or what didn't know about that pics???The first 'mod' you have to do is all the preventative maintenance. And you have to replace the parts that have timed out.
Vac hoses, check valves, plugs, wires, timing set, oil pickup, fuel pump (and hanger mods), hot wire kit, valve springs, VC gaskets, fluids, modern MAF and Translator, 60's and a matching chip, manual boost controller....
And do all the free stuff like cleaning out the intercooler, zip tie on the accelerator cable at the gas pedal, oil pump mods while the timing cover is off.....
THEN when you have a ''stock'' car (that's over 300hp at the wheels) you can start doing actual mods. If you build a house on a crappy foundation, it sinks into the swamp. Same thing with modding cars.
...or you can think about stuff like your 30+yo rubber brake lines, lower ball joints, wheel bearings, and a powermaster that's going to fail soon...
HAHA pic of it on your car Delbert !!!
pornographic memory !!! LOL
A few people have mentioned to adjust the boost. How/where is this done and is it safe ? I see many threads where people talk about blowing head gaskets. is this caused by too much boost ?
