Stock IC to Front Mount
Lvnspeeed
going for a stock IC to a front mount will you need a new tune? Or will it be close enough for now? Ta 44 with 42lbs injectors anf TT chip
Basically I am build a big motor with a big Turbo. I have been perpairing the car for the big motor with everthing it will need. I dont want to terar the car apart yet until the big motor is done being built but I want to be able to continue to install the parts needed for the big motor.
Just lower the boost a bit, and then build your way back up....you will gain a few pounds from going from the stocker to FM....:cool:
