stock location water to air IC, pump, heat exchanger
Tom Tom Turbo
Turbo Goes Woo Woo
I have an unused stretch stock location water to air intercooler. This is a 24 row intercooler, it has a large neck, accepts -10AN fittings for lines. 13x12x2 Earl's Performance heat exchanger ($260), 240 LPH continuous duty pump ($145), and the IC has been professionally notched and welded ($175) to retain the front sway bar. Also had been powdercoated black ($125). This uses all factory IC mounting, up pipe, and hose that connects the turbo to the IC. PRICE IS $400
You will need to make lines, as I never got that far with it. It will use stock IC brackets, hoses, and up pipe (not included) Although I might be able to find the stock brackets in the great abyss of stock parts that take over my garage.
http://i181.photobucket.com/albums/x110/tomtomturbo/car002.jpg
http://i181.photobucket.com/albums/x110/tomtomturbo/Picture023.jpg
http://i181.photobucket.com/albums/x110/tomtomturbo/Picture024.jpg
