Stock long block and E85
LSTTYPE
607
47
28
119
Eudora KS
Took my brothers 87 T to the track last weekend and were very pleased with the results. Ended up going 11.1 @ 120 and it went 121mph on another slower pass. It has a stock longblock with a new set of valve springs and a timing chain. E85, precision 6262 and stock location intercooler. 3 inch terry Houston downpipe and 80lb injectors. All runs were through the atr dual exhaust on 28 inch Hoosier Drag radials. Transmission is a built Husek with a Husek 3021 converter. The power master is shot and wouldn't hold more than a couple lbs psi at the line. Best 60ft was 1.65 so there's a high 10 in it easily. I give credit to E85 as it was super smooth and zero knock all day
  • Like
Reactions: broke
T-type Jones
51
17
8
57
Cool, get on Ebay and pick a e85 testing kit, you'd be suprised how many e85 stations test only 65 to 70 percent, and how much boost you can pick up at 85 to 90 percent. I did a tyno 2 days in a row with e85 that tested at 70% and the next day @85% and gained 24.17 more torque , could of got more but I didn't run all the e85 from the last gas station that tested at 70%
LSTTYPE
607
47
28
119
Eudora KS
Almost positive it was on E70. Casey's is where it came from and it tested E70 last time we checked. The fuel system is a single deatchwerks dw300, 80lb injectors, and a -6 return line
  • Like
Reactions: Marty Fairchild
LSTTYPE
607
47
28
119
Eudora KS
Precision stock location. The brakes wouldn't hold any boost so once the hydraboost conversion is done were confident it will go 10.80s.
