I have a partially disassembled 86-87 turbo motor for sale. Miles are suppose to be under 50k. It has no ring ridge. I took one main bearing cap off and one rod bearing off and the bearings look good. The bearings are GM and std. The turbo crank still resides in the block and it's of course std/std. Stock virgin 8445 heads, timing cover, still had the nylon timing gear and stock cam. Still has cast stock Buick pistons. Stock exhaust manifolds with stock turbo (spins freely and no in/out play). Complete stock intake manifold with stock injectors.
$1000 for all and I can deliver to the Reynolds event at the end of April.
