Stock oil pump cover bolts.
turboclam
I'm eliminating the longer HV gears and need stock length 10mm bolts.
Do you have some or know where I can get some? Thanks
I just looked in the garage and found a set minus the long bolt. I will check tomorrow in another box of bolts I have in my shed, but it's too dark out there. I'm almost positive I have the long one. I will be glad to mail you a set, no charge. I use 1/4-20 allen head bolts and lock washers from Ace Hardware on mine, along with helicoils in the front cover, so I have no use for them. I'll let you know tomorrow.
Thanks so much! I have the longer bolts so I'm OK there. Be glad to pay for them and shipping. Thanks
I went back out in the garage and found a long bolt. PM me your address and I will mail them to you. No charge. I appreciate the job you did on shipping me the 4.1 block. The reason I use the allen bolts is I use booster plates on my pumps, so I add 1/8" to the stock length. The helicoiled threads last a lot longer than the aluminum threads if you need to take it apart again. My Motocross engines were torn down often, so I like helicoils in aluminum parts. No surprises from stripped threads on reassembly.
