Stock Posi Rebuild
5280GN
I noticed that my posi has been slipping. I got the g body clutch pack kit and s spring. I was wondering if there are any other parts I should pick up to do the job while I'm in there. Thanks.
look at the carrier bearing very closely, as they wear out frequently,
easy to replace while its apart,.
Thanks guys. I already have the cross bolt and shaft. I did the axle seals about 3 months ago when I put in new axles. Do you need a puller to do the carrier bearings?
