The_Six
- Feb 28, 2009
Hey guys Im hoping to have my engine pulled next week I over heateded it bad Temps in the 300s and blew a head gasket.
I now have a tick coming from the engine mot sure if its a lifter or somthing worse. Im hoping that its not going to be that bad.
My car has around 130k on it so Im thinking a rebuild would not hurt. I dont want to go all out unless I have too. If the cylinders and pistons look good at the least Im thinking new barings and have every thing honed out.
Here is the list of parts I was thinking so far any thing else you guys think Ill need. Im just trying to plan for this cost wize so I have an Idea I know what a total build is going to be since I would have some one do that for me but a stock build I think Ill try on my own.
Parts list I have so far.
1> Barings cam,main, and rod
2> Roller timing chain
3>gasket set sugestions on head gaskets would be nice would stock style be ok or should I upgrade.
4>lifters
5>oil pump
6>water pump
7>cam if needed wont know until engine is opened up
8>ARP head studs
9>ARP maint studs
10> ARP rod bolts
11> rings
12> heads redone and ported by Khai
Am I forgetting any thing? Idont plan on ever going faster then low 12s high 11s and if the time ever comes that I may want to Ill build a new short block for it then with all the good stuff.
4>lifters
5>oil pump
6>water pump
8>ARP head studs
9>ARP maint studs
10> ARP rod bolts
11> rings
