GNVYUS 1
- Dec 15, 2002
This just hit me, I'm trying to calculate slippage accurately but I've been using the stock speedometer gear mph reading in the ECUGN, but this can't be accurate on a 28" tire. I know it's off but I wasn't sure about the ECU side of things and feel real slow. LOL
Stock tire 215/65/15 = 26"
Current Tire 275/60/15 = 28"
Difference = 7.65%
So when I see 50mph on the speedo and in the Scanmaster etc it's really 54mph.
The ECU can't possibly get the real and accurate mph of 54 correct?
It's not a GPS based reading, it's right out of the trans using the stock speedo gear so it's off for all of us using the bigger tires, correct?
I need to use this tire size to mph calculator then...
When I saw 84mph in 2ng gear in the ECUGN log at 6000rpm it was really around 90mph, so my slippage calculations should've been...
6000rpm
90mph
28"
3.42
1.57 (2nd gear)
3.5% slippage.
Dyno pull corrected was
6050rpm
142mph
28"
3.42
1
3% slippage
Is this on the right track or am I missing something and the ECU is reading the correct mph on a larger tire?
I'm trying to calculate slippage accurately. Thanks for any replies, it'll save me the trouble of pulling the converter if I'm on the right track.
Difference = 7.65%
Tire and wheel speed calculator based on tire size
calculator that shows effect of different size tires on wheel and vehicle speed
www.agcoauto.com
6000rpm
90mph
28"
3.42
1.57 (2nd gear)
3.5% slippage.
6050rpm
142mph
28"
3.42
1
3% slippage
