salvageV6
Daily Driver
- May 25, 2001
And do you really want that big long cutoff battery switch sticking out the back of your car, especially if you drive it on the street.
SignUp Now!salvageV6 said:And do you really want that big long cutoff battery switch sticking out the back of your car, especially if you drive it on the street.![]()
This is true. If you cant get rid of it move it back, but correcting the IC is more important to hooking these cars than playing with weight. Get the power to send the rear down and avoid making the rear squat on launch. This will allow you to leave under more boost and 60" better.murphster said:Blazer406, while the numbers are impressive, I still don't think its worth the hassle. Tweaking the suspension geometry will probably yield better results. Just take a look at my Lightning. Now there's a weight disparity if I've ever seen one. The gas tank is in the middle too, not even over the rear wheels. Adjustments to the suspension, including shocks, height, pre-load, etc enable these trucks to dip into the 1.6s for 60fts on a regular basis. My point is that while it will indeed make a big difference to move the battery, other things can be done to improve traction while not being such a pain in the butt. :biggrin:
On the other hand, it may not even improve traction that much. If you consider things like the torque from the engine and the actual force to the tires at launch, the CG probably plays a more minor role. Once you know where the CG is, you adjust the suspension to optimize it.
Maybe I should throw in some physics calculations to go with those engineering calcs.j/k
Blazer406 said:Update.... went back to the track... with re-located battery..... didn't get everything done I wanted to..... like removing the front sway bar..... and still had 32 psi in the new 275/50 MT drag radials..... went a 1.71 60' time on a 5 psi launch. I hope there is alot more there on a harder launch... still .1 better to 60' than my previous best 60' is at least going in the correct direction.
New times in my sig..... in search of 11's on the stock turbo/stock longblock full weight car.....
petesgn said:How much boost where you running ?
Blazer406 said:21-22 psi .......
need to get the modified grainger valve installed too..... might would spool up faster.... enabling me to leave soft... but spool up REAL quick.... not shocking the tires quite as hard....
petesgn said:Your doing pretty good .![]()
Blazer406 said:went a 1.71 60' time on a 5 psi launch.
UNGN said:Unless there was knock on the 2-3 shift, 106 mph on that run sounds like you are out of RPM.
What is your RPM through the traps?
If its 5000-5200 RPM at only 106, time to switch to 28" tires or lock the converter.
Nocooler said:I went 12.30's@109.5 w/1.72 60'
Stock turbo, Dut. Neck, Stock injectors, Stock Engine, Thrasher 108 chip, TCS 9x11 (2800stall), etc, etc.
It had alot of little stuff done.
This was thru the exhaust and on pumpgas/alky, with an open rearend.
I removed alot of weight from it - but couldn't get the 60's consistant, and it went 12.30-.40's @ 111mph.
Timing is the key to making a stock turbo car fast.
Blazer406 said:How much timing were you running? I am currently at 25/21
Lower the shift rpm (4600-4800) and run the tallest slick you can get in there. Raising the shift rpm will slow you down. Crank the boost as high as possible. The lower the rpm, the higher you can crank the boost and still make more power. You will be blowing nothing but hot air at 4800 rpm and 25+psi boost. Way out of the efficiency range of the turbo. My 111mph runs were with 26*. I ran a 29.5in slick.KEVINS said:Question: What RPM's are your car's shifting at? Mine is around 4800-5000 no higher so I will need to raise the shift RPM to see if I gain any MPH. I've run timing anywhere from 25 *to 28* and mph never changed.
ks![]()
