Blazer406 said:
I should be able to get there... just some 60's in the 1.50's would do it for sure..... If my math is correct.... looks like I need a sub 7.60 pass to go in the 11's...... that is .4 seconds off my 8 flat pass... I see .2 in the 60' for an improvement goal..... that .2 in the 60' might get me .3 in the quarter.... Seem reasonable?
1.50's would probably be a little optimistic. Lets say flat 1.60's. Might get you down .15 in the 1/8 and close to .2 in the 1/4. That puts you right at 7.8. To get down into the 7.6's or so, you'll need to make more power either by adding more boost or more timing along with tweaking the alky and fuel.
Blazer406 said:
I am not necessarily looking for a faster pass.... just a quicker one.... Your above analogy makes me wonder where the differences in your car and pacecarta.... boost control..... does his spool up faster than yours? What are the differences in the converter.... I plan on having the grainger valve installed before I go back....hopefully it will spool so fast... I won't need to leave on much boost therefore making it easier on the tranny b/c I won't need to build as much boost as I would if it spooled slow... to get the same 60'.... ie. fast spooling car leaves at 2# .. and cuts a 1.5 50' ... and the same car... with a different boost control method... that spools much slower... (all other things being equal).... might need to leave on 12# to cut the same 1.5 60' time..... Make any sense?
There is no real magic boost to leave at. Between the chips, suspension, converter, turbo condition, yadda, yadda, no two cars are alike. Only after many runs will you find out the best combination. Maybe your car will like leaving with more boost, maybe not. Basically, you want to leave with the most boost your car will handle without spinning, grainger valve or not. Pacecarta took off his boost controller, launched with less boost, and had even better 60's! So, its hard to predict what works. For a while, pacecarta and myself had identical chips, tires, injectors, rear bar, and converter. Our cars still launched totally different. Just too many other variables. The only thing I know for sure, is that I have to leave with more boost on 28" tires compared to 26" tires to get the same 60'. The best thing will be to write down all of your settings for each run and make your own baseline so that you can get an idea what works for your car. I made a spreadsheet of all my runs and write down just about everything I can think of. Now I can go back and see how the car started running slower when I blew my rear, then fuel pump went bad, then plugs fouled out, and finally my turbo was deteriorating the whole time.
The best three things I did to the car were the HR bar, MT drag radials, and alky kit.
Blazer406 said:
My chip is an oldie.... probably going to order a new one soon.... it wouldn't let me adjust timing except WOT.... and that moved it for all gears...ie 23/19 I think was the base setting..... I am stuck with the 4 deg split..... when I move it up.... I can increase timing.. like I already did... but it keeps the same 3 deg split.... I am at 25/21 now....
4 deg split isn't bad. You could eventually run 27/23, which would be about the most you'll want. The most advantge you can get from a new chip is you could send Eric a DS file of your run. Maybe you are too rich on the launch, too lean up top, etc. He could taylor the fuel curve more to your cars needs, along with some other tweaks.
