in 1994, car had a external fuel pump, fuel reg. Cut hole in stock DP at the very bottom of the curve of the pipe.Took the road light out and made a ram air to K&N (which I still use) Everything else was stock, even the chip.
Took the spare tire out and ran lexan t-tops, ate ramen noodles for a month and lost about 15lbs, so the car was as light as possible. Had an adjustable actuator set to 21 psi, pump gas with 104 additive. Probably was knocking. Shi**y Goodyear radials ran 1.89 60 ft' and 12.90 @108.9 mph.
