stock valve cover gasket replacement w/HR mounts?
What is a stock valve cover?? :)
Bryan
I have the tall valve covers on mine with HR mounts and that back bottom bolt is a PIA to get loose to get that valve cover out , the stock VC is a piece of cake compared to them
TA low profiles here. No problem at all. Heat shield removed
Bryan
Well... The valve cover change went without a hitch!! Didn't have to remove or loosen anything. Just some wiggling of the valve cover. I attribute this ease of change even with the heat shield to the fact I have the poly body mounts. Apparently the body's additional height is just enough!! :D
