Originally posted by d0n_3d
i keep hearing people talking about spraying methanol instead of alcohol...right now i spray 100% denatured alcohol with a dual nozzle smc kit and i've got the boost up as high as 25-26 psi with a te-44 and stock motor stock intercooler...with no knock...
if i go any higher i start knocking...usually higher than 25 psi...will methanol allow me to run higher boost just a little bit? i heard methanol is very corrosive and should not be used...i assume i can't use it in a stock SMC setup right? i would love to use methanol if i can run higher boost on it than alcohol and it even costs way less...
Looks like you hit that performance wall with the SMC kit. Two problems, first is that 25-26 is about the limit of that TE44..before it starts really heating the air, then you have the limit of the amount of flow out of the SMC kit... When pump speed 10 is no longer enough
You can start upping the timing and upping the boost, problem is you need more alky and less fuel. Rite now you have a lot of fuel and some alky.
Steve doesnt recommend using methanol with the pump in his kit. I have a buddy that increases the amount of Klotz and has been running Methanol since April this year.He only runs 22-23 PSI of boost. So far so good..but hey..I cannot recommend against the kit builders recommendations. Next problem is that the pump in the kit wont flow what you need/want to really get serious.
You've outgrown your 20 PSI kit..time for some decisions..
Try adding water since its unlimited octane...
No dont do this..
