strang tp change
van460
have the new mt drag radial and used on stock wheels at 15 psi and had 1.55 60. desided to put on my tens with same pressure and all i can get is 1.65 or worse and cant leave high on stall. tried all the way down to 12 psi did not change any ideas on these tires, im about ready to put back on the stock rims. i did install a hybrid boost controller so the boost does senn quicker, but it should still hook.
What size of the new MT's are you using? Do they rub with the stock rims or are you using spacers? Thinking of getting this tire for my GN in 2.75/60's and putting them on the stock rims. Sorry, I don't have an answer to your problem. Thanks
275/60/15 this is all you can get right now, and they do not rub with stock rims.
i have 275/60s, 275/50s and 235/60s in my garage, Ramchargers has them in stock...........
you flattened out the sidewall by using 10" rims........they should hook better on a 7 or 8" rim....taller sidewall, more flex
wider isn't better
any idea with the tens(tp) though, i like to keep them on the rims i drive on. or you just suggesting to put them bavk on stock rims?
7" rim is a bit small for a 275X60, but lots of folks use 'em that way....if you want good hook, use the 7" rim (8" would be ideal)
