- May 28, 2001
Just completed a preliminary flow test on a set of Bosch gray tops...As the bench pressure came up to 45psi, 5 of the 8 injs started leaking at the joint where the plastic top is sealed to the metal case. 1 was so bad, that flow fluid filled the plug socket!
This is the second set I have seen do this. The first set had 7 of 8 leak.
All 16 injs had been run on methanol, in hi hp outlaw cars. [At very hi fuel pressures, hi boost].
I've not been able to disassemble an inj, as the customer took them with him.
My suspicions:
1. Hi op pressures are exceeding the seals ability to hold.
2. Methanol is degrading the seal.
NE1 have this problem??? Could be fatal, should a fire occur...
The REALLY SCARY part: Neither customer was aware of the leaks....
My suspicions:
