- May 25, 2001
I have a annoying issue i'm trying to track down. Today was the first day I was able to take my car to work and get a few miles on it since I had the engine done in Nov/Dec. It ran great except one thing.
In gear, moving, at 2000-2150 RPM ONLY it makes a metallic rattling sound. It is a rapid vibration sound. Below 2000 RPM and above 2150 RPM according to the scanmaster it does not make the sound. I can make it do it sneaking up to the RPM range or coming back down.
It has had this noise before the motor was rebuilt. it has done it with a stock DP/Cat (what I have on now to smog the car), a THDP/gutted cat, multiple different turbos, water pumps and power steering pumps. Only the Alt and idler pully have not be changed. It's not the IC, the car had a FMIC on it and now a V4 and still has the same noise.
I haven't been able to find any loose heat shields or anything like that. I have a TT chip so I don't think the EGR is being used but all of that is hooked up. (there was a thread I found searching that people had EGR's make strange noises).
Any ideas?
Any ideas?
