jpwalt1987
- Nov 9, 2003
Ive got a really weird timing event occurring and I was able to capture it on the powerlogger. When the gets up on boost timing will be steady at 19* then it will misfire and buck. The PL showed that timing went to 85*!! I decreased the boost and got higher rpm before it acted up. With higher boost it acted up at a lower rpm. That leads me to believe that it is load related. Otherwise the car drives great. I will test the coil and module in the morning with a Caspers tester but I figure its between the coil/module or crank sensor. The BHJ balancer is tight and the reluctor wheel is also tight on the balancer. Any ideas?
