STRIPPED TURBO OIL FEED LINE
john saleeby
Other than buying a new oil feed line, is there a way to replace the fitting that screws into the fitting on top of the turbo?
You could cut the flared end off and side a new fitting on and re flare if there's enough room. Replacing it is a lot less hassle
the fitting in the turbo is brass , the feed line is steel
if anything the fitting in the turbo is bad ,
on stock turbo and some others that fitting is 1/4" invert flare 90* to 1/8npt male
as bison said you could replace the tube nut available at most auto parts stores and reflare the hose , its a male 1/4" inv flare tube nut
I'm with Bison on that. Any other methods are more work, compression fittings are risky in that area and look shady. A new line is like $40.
The fitting looks/feels aluminum. I ordered a new line from Kirbans. Thank you for the input guys.
Start the fitting into the turbo before it is tightened down. That will allow some leeway in getting the threads started correctly.
RemoveBeforeFlight
