You wont notice much of a difference on a street engine. The rod wont be significantly longer than stock so the rod stroke ratio wont be affected enough for you to notice, About 1.7529 for the stock rod and 1.764 for the 6" long rod. A Rod Stroke Ratio of 1.75 is considered “ideal” by some respected engine builders,
if the breathing is optimized for the design. The longer rod will help in turning the motor to a higher RPM more smoothly due to higher piston dwell time and the angularity of the rod. That is the main advantage of the length - the shorter the rod, the more stress on the cylinderwalls, wrist pin, piston and crank.
HOWEVER, you want to build a stroker engine, which changes around the rod stroke ratio significantly! using a 3.625 stroker crank and a 6" rod will give you a 1.655 rod stroke ratio and a 1.644 on a stock rod
- which is less than favored by some- and is to our disadvantage in buick V6 world. the reason this hurts us is because of cylinder heads. As Jerry above posted about Rod Length - Shorther rod stroke ratios that fall into the 1.45 to 1.75 range tend to favor Large intake port volume vs. motor size- such as a nice Champion, TTA or Stage 2 head. Hmm.......? starting to see why buick engineers built the motor the way they did.
In My Honest Opinion, These are factors really only needed on a race engine where every little detail counts, Smokey Yunick once said that he threw a handful of different rod sizes at his stage 2 and never noticed much of a change in power. you may pick up 3 to 4 hundred rpm at the top end, but nuthing more than that warrents the expense of longer rods in the Buick V6 - its money better spent on porting, valve work, a well chosen cam, intake..... concentrate on BREATHING.:biggrin:
Good Luck.
A.j.
P.S. oh yea.......... go Navy.
