- May 28, 2001
The floor in my house is sagging to the point that the walls are cracking, and the bedroom door won't close.
I've purchased 6 ceiling jacks, [16,000# cap], some 2x10's for added beams, to address the problems.
[The idiot that built the place set a stone FP on the floor, and added no additional supports.]
The house showed no outwardly signs of problems until I moved my entertain center in. The "balance" was tipped, and things headed to the crawl space..
The ??'s
1. Once the jack locations are determined, what should I use for a base? Ideally, it's a poured foundation, but that's pretty much impossible, due to the limited crawl area. NE contractor folks have idea?? [The ground is VERY hard, dry, red clay.]
2. I have some 1/4" steel plates, about 12x12..Would that work, or should I use 4" cap blocks, laid on their sides? Or??
I'm going to temp in some jacks today, to try to stabilize the walls, and make permanent changes ASAP...
The ??'s
