Stuck compound in jambs
Turboboy
What do you guys use to get the compound out of the jambs? i tried glass cleaner and more compound and its still there. I dont know if i should use a super duty compound or not. What do you guys recomend? thanks
That compound gets really tuff to get out after it dries dosent it. The only thing that I have found is warm water with a little soap and a soft sponge. You'll need plenty of elbow greese. I have used my finger nail sometimes on the really thick stuff. After it has soked for a wile.
Of course the best way of taking it off. Is to do it before it dries as your buffing the car. I know a little late now. Right?
I use a pressure washer. If it's really set up it will take some doing, but the high pressure water will be able to get to places you can't get with anything else!
