Has anyone had the problem of having their transmission being stuck in 1st gear? One morning I backed out of my garage drove out of my driveway onto the highway and my TTA would not shift out of first gear. So presently I have reverse and 1st gear. I dropped the transmission pan on the suggestion that the spring in the governor may have popped out, but the spring and check balls in the governor were all there. Also the oil was clean and there was very little material clinging to the pan magnet. I might add that when this problem occurred I notice that it didn't "feel right" when I pulled the shift lever into reverse and backed out of my garage. In fact there is a "little bit" of a rattling noise when the car is idling in reverse.
I am not sure what to do next, short of taking it to someone who is more knowledgeable to troubleshoot. I am stumped.
I might added that I bought a transmission filter from O'Rielly Autoparts to replace the trans filter while I have the pan dropped. It has a "lint trap" type of filter medium instead of a nylon mesh, and was mfg'd in Taiwan. I think that I should get the AC Delco trans filter. While I was at it I added a drain plug for the future, so I can drain the pan before I drop it.
