OK, as most of you have figured out by now, I'm a tuner, not an assembler, hence the rooky questions.
1. Got the rings installed and ready to stuff the piston/rod assy's into the block. Are there any special preps to do to the rings or cylinders?
2. I have looked at two sources for ring orientation and they don't agree. The service manual shows the oil ring spacer joint 90° from the front of the engine(pointing to engine right).??? and of course the oil rings 120° either side from that point. Then the 2nd ring opposite the spacer joint, pointing to engine left, and the top ring opposite of that pointing to engine right.
While the sheet that I got with my Sealed power rings show the oil ring spacer joint directly over the pin boss, which means it should be pointing to engine front, and top two rings arranged similar to above. (ring two opposite spacer joint, top ring over spacer joint).
Those of you that are assemblers, how do solve 1. and 2.
